Layer Material Coat rendering transparent
  • Layer Material Coat rendering transparent
    Hello, I would like to use clear coat and wooden texture as base material. However coat renders as see-through. Should you not see base material through it?
    Daniel
    It's hard to tell without a scene.
    Are you sure the base material is not transparent as well ?
    Greetings,
    Vladimir Nedev
      Hmm, no base Material is not transparent. I have sent you the scene.
        I have reproduced this in simple scene too. Materials behave as a simple combination of two materials and not as a stack of base and coat.
          I finally took a look at the scene you sent me.
          You have added refraction to your coat material, that's the reason the whole material becomes transparent.
          I think that's how it's supposed to work.
          If you want to see less of the coat material, you should either use its opacity channel/texture or its blend amount in the blend material.
          For a coat layer, you don't want to have refraction.
          Greetings,
          Vladimir Nedev
            if you use opacity, will it work if set Methode to clip?
