Shouldn't I be able to use Vray Next Render node with Vray 3 workstation License?
  • Shouldn't I be able to use Vray Next Render node with Vray 3 workstation License?
    So I am using Vray for Modo 3.6 workstation and evaluating Maya Vray Next. I wanted to see if the Vray Next Render Node License would be compatible for Modo Vray 3.6. Unfortunately It ended up doing a loop of the transfer for the vrscene with distributed render. I am guessing that it may be a bug?
    I don't want to purchase the wrong render node license as well. So it would help if someone could clarify what's going on.
    Thanks.
    Edit:
    The FAQ said it should work so I don't really know..
    See my answer here - https://forums.chaosgroup.com/forum/...chase-vray-3-6
    Ivan Slavchev
    SysOps
    Chaos Group
