Hello,
I'm using vray 4 and I'm having a lot of Cuda Error 700 (cf attached image) using modo 11 or 13 and most of the time modo crashes
I have two Gtx 1070 gpu and have errors only when using the two gpus, if I use only one of them it's ok
I don't use c++ cpu
I don't have problem using RT
I have installed the latest drivers from nvidia
Is there a stable version you recommand to use with vray for modo ?
To go faster when I relaunch modo I'm using this command line : "?vray.render.animation {} gpu {} {} true simpleRange 73 145 1 {}"
However modo always ask where to put render images. Is there a command to automatically specify the path and image name so I can relaunch renders with one or two commands ?
Thanks
I don't use c++ cpu
Thanks
