Nvidia denoiser produces corrupted alpha on final renders
  • Nvidia denoiser produces corrupted alpha on final renders
    I'm just doing a quick test using the nvidia ai denoiser. It seems to be working just fine in RT GPU. All the REs look correct.
    If I use it for a final GPU render, everything looks OK, except for the alpha RE. The bottom of the image looks inverted.
    1. Load attached scene
    2. Top menu > v-ray > render with v-ray > render engine = GPU
    If you watch the alpha RE while the buckets render, everything looks OK, until the denoiser runs at the end.
    Win10 Pro 64 / AMD Ryzen 9 5950X / 128GB / RTX 3090 + 1080 Ti / MODO
    I am the resurrection, and the life: he that believeth in me, though he were dead, yet shall he live - Jesus Christ
    Hey, John,
    Thank you for the feedback. What I am missing with your scene file because I am not able to reproduce it? Nvidia driver release version 417.19.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      I'm on modo 12.2v2, v-ray nightly 29113 and 430.64 nvidia drivers.
      I guess it's probably a driver issue. I updated to 430.64 due to a security update:
      https://nvidia.custhelp.com/app/answ...curity-updates
      https://www.forbes.com/sites/kevinmu...graphics-card/
        Originally posted by boyan View Post
        Hey, John,
        Cheers,
        By the way, are you sure about your driver version there? I couldnt get the nvidia denoiser working with 417. I thought you needed 419+ ?
          I installed 419.67 to test them out and I still see this issue
            I got Mark to test this on skype too and he sees the same bug
