Distrubtion Rendering stop working
  • Distrubtion Rendering stop working
    Distribution rendering suddenly stopped working. Local machine (which is not being used in the DR) goes through all the normal loading and sending, but then hangs on the image attached. The render servers show that they're "Receiving the scene..." but nothing happens after a long wait. It's a scene I've already rendered with no problems. Is there an error log to see what the issue is? I've rebooted the render servers as well as my local machine, but still have the issue.
    Do you have enough free space on the disk of the slave machine ?
    You can enable more detailed logging by passing "-verboseLevel=4" on the command line when starting V-Ray Standalone in slave mode.
    Greetings,
    Vladimir Nedev
      Thank you Vladimir. It looks like it started up, but just longer than normal. We should have plenty of resources on our slave machines. I will check out that detailed log to see why it was taking longer. Thanks again.
