Hi
I've exported textures from Substance using the VRay preset and am rendering with VRay in Modo. The texture is not displaying correctly - please see Substance metal vs VRay render.
In the Substance docs - https://docs.substance3d.com/integra...157352249.html
it looks like you can just plug everything into a standard VRayMaterial - diffuse map is black as I have a metal.
Substance exports with a gamma of 2.2, and Modo defaults to 1, so I've left everything as it is
+ Substance docs mention to change Normal,Glossiness and IOR to 1 for Maya, but assuming this is ok for Modo?
+ Do I need to set diffuse and Reflection to 2.2, or just leave everything as default?
Any help very much appreciated!
Thank you
Thank you
