There is a problem with the smoothing angle setting the vray material. What ever you set it won't affect rendering. Even when creating a linked OpenGL Modo material it doesn't work. It seems Modo can't deal with linked values on smoothing angle input, if you unlink it, it works.
Anyway It should work right out of the value in V-ray material. My current workflow is setting a Modo material under the V-Ray Material that is not linked and then place the value here. However that seems not really a good choice.
