I have a displacement that causes clear elevation steps in the render image. Its an 8 bit image, so that may be one reason, but isn't possible to smooth out the result with anti aliasing, so the steps become flat?
Displacement issue
Hey, Robert,
Thank you for the post. Add V-Ray Geometry properties to selected mesh and enable Displacement option, Next is to enable the 2D texture and change the resolution to match the texture, If this does not improve the render quality, please disable the Use global settings and decrease the Edge length. This can cost you an increase in render time.Boyan Nalchadjiiski | QA Engineer @ Chaos |
E-mail: boyan.nalchadjiiski@chaos.com
