Can't lauch render with Alembic file if is having an UV
  • Can't lauch render with Alembic file if is having an UV
    I have an issue importing an Alambic Animation.
    The V-Ray Render dosen't start if an object in the alembic file as an UV
    Have nice day.
    Best Regadrs
    Daniel
    Hey, Daniel,
    Thank you for the feedback, Can you upload the alembic with V-Ray Proxy? I think this might be fixing the problem.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Sorry for the delay,
      i going to try with the proxy thabk you for the idea.
      here the scene file,
      if you made the layer visible "huile test Not To Render" the render dosen't start.
      Have a nice day.
      Best Regards,
      Daniel
        Hey, Daniel
        Could please check the setup// Happy rendering
        Cheers,
          Hi Boyan,
          Perfect thank you . !!!
          Have a nice day.
          Daniel
            Hi
            i have an issue with i think the velocity when i use the proxy.
            i needed to scale down to 1% to match the scale of the scene.
            and we see the dropplet ofn the left blurred out i try to fix on the velocity multiplier but nothing append.
            if y scale before i exported from houdini it worked.
            but my problem i just finish calculate a simulation 30Gb (20h00 ) and i don^t want to relauch it .
            do you have an tip to fix it please ?
            thank you very much for your help.
            Best Regards
            Daniel
              Hey,
              I think you can try with File -> Import Reference (the reference scene file is your initial scene / or you can add the new one with animation only) the scale is easy when you add reference image //
              Cheers,
