Admin vs User
  • Admin vs User
    Hello all, I am running into a situation where I have to run Modo as admin for it to recognize the Vray plugin. This means everytime I need to run Modo (which is daily) that I have to have the admin login and start the app. Does anyone know of a work around for installing the plugin and not have to use the admin account to install or run the app?
    V-Ray for Modo is installed only for the current user, I don't think it matters whether he is admin or not.
    What you can do is go to %appdata%/Luxology/Configs on the admin account and copy the vray4modo.cfg file to%appdata%/Luxology/Configs on the normal user account.
    Then it should run on the normal user account as well.
    Greetings,
    Vladimir Nedev
