Render node stops after first frame
  • Render node stops after first frame
    Hello
    I have a licence of vray for Modo and a render node. Since some days ago everything worked well and the 2 computers (one running modo and the other just th enode) were working well.
    Now after the first frame the render node stops
    without any warning or error, just as if it has ended its work, while in reality there are a lot of frames yet to render.
    The main machine keep working without any issue.
    What might be the issue?
    I had the same issue when distribution rendering with large scenes. The best solution I found was using V-Ray standalone.
      Thanks Larry! I tried that and it works!
        Awesome! I'm glad I could help. I've received a ton of help from the community and it's nice to pass it along.
