set focus not working in gpu
  • set focus not working in gpu
    hi - with modo 14 it seems like the control+shift with lmb no longer sets the focus point - control+shift and scroll wheel still adjusts the f stop - and they both work in cpu mode - I am using the latest nightly build - is this correct?
    Do you have RTX mode enabled ?
    Greetings,
    Vladimir Nedev
      ok got it.... if I set the focus and then enable RTX after its already rendering, will RTX mode work, or do I need to restart the render? is this something that will be worked out in the next version? thank you
