Render animation results in no saved files and only last frame visible in VFB
  • Render animation results in no saved files and only last frame visible in VFB
    When I render an animation, after choosing a name and location in the 'Choose output image' prompt, they are not actually saved on that location after the renders complete and the VFB is also not much of a use since only the last frame is visible.
    Is there perhaps a temporary save location where they still could be found?
    What can I do?
    (EDIT) I have found out that it is project file related, when rendering an animation of a simple cube in a new project the frames are being save just fine.
    (EDIT2 - Solution) Ok, I didn't have a Final Color Output layer, without that layer nothing is saved (even other layers that I did have like z-depth or AO weren't saved).
    ps, when I send an animation to the Chaos Cloud, I choose PNG as output but the cloud renderer only wants to give me EXR and JPG... even though the faq claims that you can set it to any output image format.
