Vray proxy missing paths
  • Vray proxy missing paths
    Hello,
    I don't know if this is a bug or feature request, but I loaded a scene with a lot of Vray proxies and the paths are wrong as I was working on that file at home. Is there a way to get modo dialog asking for missing proxies, because changing paths manually takes forever?
    Thanks a lot
    I need to do some experiments on this. It is a problem, but I am not sure the MODO dialog can be invoked automatically, maybe
    we will have to re-implement what it does. There is a way to mark a string channel as a "filepath", but last time I checked it didn't
    do anything.
    By the way, do you happen to use "path aliases" in MODO or do you rely on the "missing textures" dialog.
    Greetings,
    Vladimir Nedev
      Thanks for your reply Vlado. I don't use path aliases, just missing textures dialogs if a file is not found.
