modo crash when a render start
  • modo crash when a render start
    I sometimes get that modo crash when I start a render.....but it is not a repeatable bug. I can open the same file after the crash and it will render fine.
    So...not easy to bug. Is there a log or something I can look at to find the issue? I dont think it is a scene...it just happens at random. Anybody else getting this?
    Hello!
    I would suggest using the Modo event log monitor but in this case it will most probably be of no use.
    You can search for a VRay.dmp file in your user \AppData\Local\Temp folder. Sometimes it has data that points out where the problem occured and is very useful to the developers.
    Margarita
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
      Hi Margarita
      I will have a look if it happens again, thx!
