Hi, turning on "Anti-alias masked render outputs" doesn't work if adaptive method is set to Default. Legacy works fine.
You can easily check this if you create two adjacent materials and make them 0 defuse and both pure white in self-illumination. Create alpha outputs for both materials. The border between them will not be anti-aliased in alphas even with this option checked with Default sampling method. The same border is ok if you switch to Legacy method.
