Can you tell me what nightly build you are using ? I guess you know, but just to mention it, you should have the same V-Ray for MODO version on the render client and slaves.
I guess you have this option enabled ?
Can you check the log on the slaves that don't render correctly and attach it here ?
I did a quick test and the asset transfer seems to work properly, so it must be something a bit more complicated in your case.
Sorry for not answering - couldn't find time for more tests. Today I wanted to perform another render just to save the log and everyting renders fine. Slaves render proxies without problems on modo 801 as well as on 10. It was probably a problem with my internal network.
Another reason for this failure might be insufficient disk space on the render slave.
The transferred .vrmesh file needs to be saved on the local hard drive of each render slave.
