Crash selecting lights in this scene
  • Crash selecting lights in this scene
    I was taking a look at an older scene someone posted on the modo forums and discovered that vray crashes when a light is selected.
    I stripped the scene to a bare minimum so you can take a look.
    Load the scene then select the first light in the "lumieries" folder. Modo will crash. I'm using modo 10.1 and vray 26623
    Win10 Pro 64 / AMD Ryzen 9 5950X / 128GB / RTX 3090 + 1080 Ti / MODO
    I am the resurrection, and the life: he that believeth in me, though he were dead, yet shall he live - Jesus Christ
    The crash is actually in the MODO code. It crashes when V-Ray for MODO tries to add its "V-Ray Light" package to the light.
    You can disable the automatic adding of the "V-Ray Light" package and recreate the lights, as it seems there is something wrong with them.
    If you want to reproduce the crash without V-Ray, so you can report it to The Foundry:
    1. disable the V-Ray for MODO plug-in
    2. restart MODO
    3. open the scene
    4. select one of the lights
    5. go to Dynamics -> Make Active Rigid Body, MODO will crash
    I am not sure it makes any sense to make a light an active rigid body, but it adds a package to the light, which is how the crash happens.
    Greetings,
    Vladimir Nedev
      Thanks Vladimir. You're right. I'll report it. You can just select the light > display > add note (or any of the display packages) and you see the crash
