Problem with texture Projection
  • Problem with texture Projection
    Hi Vladimir,
    I have a strange problem where VRay is not picking up my texture projection properly. It is a cubic projection(you can see it on the attached screenshot).
    On the stone next to it it works perfectly. I am so fresh in VRay that I would not dare to call it a bug, probably user error, but I have not been able to figure it out. Do you mind to have a look?
    I have put the file here on Dropbox https://www.dropbox.com/s/c7resjk5hf...ction.rar?dl=0.
    Cheers,
    Jonathan
    Cubic mapping doesn't work with Vray, use Box mapping.
      Thanks Robert.
      Actually it seems to work, I just had set the bum too high by mistake and that for some reason screwed up the image...
        Cubic mapping should be working in CPU mode. It doesn't work in GPU mode for now.
        Greetings,
        Vladimir Nedev
