failed to export with unknown error
  • failed to export with unknown error
    Vladimir, I am suddenly getting the error:
    I am sending you the scene, please can you see if you can render it?
    To render the scene, delete the object called "BOXLIGHT", it is a mesh instance without a source mesh.
    I had a check in the code for such cases, but probably broke it somehow when adding support for the "allow deformations" option of mesh instances (the 2016.07.29 build).
    Should have added a test for this. Will write back here when the check is working again.
    Greetings,
    Vladimir Nedev
      Vladimir, thanks for checking so quickly, you are a lifesaver!
        The crash is fixed for today's nightly build ( 2016.08.18 ).
        You should update to avoid any surprises.
        Also the Event Log now includes a warning about mesh instances that don't have a source mesh.
        Greetings,
        Vladimir Nedev
