Way to get VBF quick single RE image save out to remember the last directory used?
  • Way to get VBF quick single RE image save out to remember the last directory used?
    Is there a way to get the VFB to remember what directory you used last to save an individual RGB RE image? Click image for larger version
    It keeps reverting back to the MODO install directory and I end up having to re-navigate to my save directory each time.
    Hey GidPDX,
    Appreciate you comment. This is an issue and we working on it. I'll keep you posted about it.
    BR Boyan
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Thanks Boyan.
      Yeah, it's one of those things that if you just do it a few times a day isn't too big of a deal, but right now on this project it's kind of irksome.
      Luckily the render times and render results are so nice that I'm happily putting up with it.
        yes quite annoying, meanwhile, you can put a shortcut pointing to your render directory in the modo install directory
          Ah, that's a good tip. I was just using my quick access bar to do similar, but this should save even more mouse clicks.
          Thanks ratus69!
          Edit: Weird that vray wants to look in my 902 directory instead of the other installs like 10.1, 901 etc....
          Oh, and windos 10 is such a PITA- have to make the shortcut on the desktop first and then put it in the MODO install director. Rejoice!
