I have a constant problem using team viewer with Modo V-Ray. Not sure where to start debugging it.
I usually team viewer to my render farm, setup the animation directly in Modo and hit render. The problem I run into is that once I shut down team viewer there is a 50% chance that V-Ray freeze or hold during rendering. The pause effect is actually killing Modo. Modo screen shrink down to little black square window and is unresponsive. Only shot down by force helps.
I run into that now so often that I wonder what it causes. If someone has similar problems please respond.
