Render node - could not obtain a license error (-65533)
  • Render node - could not obtain a license error (-65533)
    I am getting the following license error on our render node machine.
    Everything was working fine and there has been no updates on the mac however now when I start the vlservice in terminal I am getting the following error.
    I have updated to the lasted build of the license server.
    The render node is using Mac OS Sierra if that is of any help.
    Thanks in advance
    Is your license server running http://localhost:30304/#/ ?
    Can you ping it from the slave ?
    I have no idea what that error code means.
    You can write an email to support@chaosgroup.com , they have experience in solving licensing issue.
    Greetings,
    Vladimir Nedev
      yes the license server is running.
      It was working fine with no problems then all of a sudden its stopped working and flagging up the error code.
      I will write to support.
