Render Outputs get rendered even if output is disabled.
  • Render Outputs get rendered even if output is disabled.
    Yeah thats kind of a bug, but render outputs get rendered in V-Ray even if the user have them disabled in shader tree. Only workaround is to delete them, which is a problem if you want to render in passes. So a simple Black White pass will be saved with all the outputs the user defined.
    Also if delete V-Ray 'environment render output' dialog will still list the deleted as active. Different, but not so big bug.
    Hey Robert,
    Thank you for the post. If you disable RE's folder only, yep this an issue and we working on it. Do not delete RE just open folder and disable the desirable renders.
    Hope this is your case.
    BR. Boyan
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      This should be fixed in tomorrow's nightly build ( 2017.01.31 ).
      Although I am not sure this was the original issue.
      If not, please provide a sample scene or screen-shot at least.
      Greetings,
      Vladimir Nedev
