Event log not updating during render- how do I enable this?
  • Event log not updating during render- how do I enable this?
    I'm just wondering how I get the event log to update while rendering? I somehow disabled this or something, and now can't see what's going on until after the render is completed.
    Thanks! -g
    In newer version of Vray it only pops up only on warning or error. You can make it so it's always open when rendering by going to the "Settings" tab. It's right under the distributed rendering. Where it says "Log window" open the dropdown list and choose "Always". You should now always see the window. You can also open it through the VFB. It's the little blue square icon in the bottom right corner.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    3ds Max 2023.2.2 + Vray 6 Update 2.1
    AMD Ryzen 7950X 16-core
    64GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 551.86
      I can actually always see the window just fine- it just isn't updating as the render progresses.
      On a side note...I can't seem to find that preference you're talking about...where is it located? I'm sure it's right under my nose.
Name:	Vray Event Log update.JPG
        Oops, I just noticed this is in the Modo forum, sorry. I was thinking about 3ds Max.
        Aleksandar Mitov
        64GB DDR5
          Thanks! -g
          At some point I will have to add our own "Render messages" window similar to the one in 3ds Max.
          I am not sure it's possible to make the MODO event log update while V-Ray rendering.
          Currently only the V-Ray progress bar will give you real-time information about what is being the done.
          The Event Log is useful only after rendering is complete/aborted to check for statistics/warnings/errors.
          Greetings,
          Vladimir Nedev
            OK, thanks for the low down on that feature Vladimir. I'll stop looking for the magical setting that lets it happen.
