VRay Environment Fog and Opacity Maps
Hey Ray,
Thank you for the feedback. Can you provide the scene file, if it is possible?
BR. Boyan
E-mail: boyan.nalchadjiiski@chaosgroup.comBoyan Nalchadjiiski | QA Engineer @ Chaos |
E-mail: boyan.nalchadjiiski@chaos.com
Hi Boyan,
Here is a dropbox link to the scene in question.
https://www.dropbox.com/s/o3t1wh115q...Scene.zip?dl=0
Thx
Ray
Thank's Ray, I will check it and reply to you. Keep you informed.
BR. BoyanBoyan Nalchadjiiski | QA Engineer @ Chaos |
I took a look at the scene and I am not sure whether that's a bug or some sort of sampling error.
You have your fade out radius very high - 2km, while the fog distance is very small - 4mm, with a large step size - 1m.
The docs suggests that the step size should be 2 to 3 times smaller than the fog distance, although this depends on any density textures you might use.
In your case this means 1-2 mm, but even that doesn't fix the issue and is also very slow to render.
I suggest that you reset the fade out radius to 0, and use a large fog distance, something like 1m.
You might have to lower the fog gizmo closer to the ground.
Here is what I got. Note that the gizmo is lowered. I am not seeing the opacity issue.
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
Hey Ray,
Yep, Credits are to Vladi Nedev .
Keep posting, your feedback is important for us.
