render elements
  • render elements
    I got only RGB PREVIEW under render elements. I can't see and select any of the render elements as it's set under settings. Also it's scaled down and not in full resolution ???
    How can I disable it and return to normal render elements?
    www.studio-grid.net | creative imagery of unbuilt architecture
    Gumroad Facebook Vimeo Linkedin
    This happens when you are saving the image to "tiled EXR" format.
    The VFB is automatically switched to "preview only" mode to save on memory.
    This way you can render huge resolutions (20K or something) for print.
    If your resolution is more normal, just switch to a non-tiled EXR format.
    Greetings,
    Vladimir Nedev
      Hey, bbgrid.
      Thank you for the post.Well, this is expected behavior when you add the render elements while rendering. Stop RT, Run it check the result in VFB. If the issue still exists, please send to me the scene file.
      Cheers,
      Boyan Nalchadjiiski | QA Engineer @ Chaos |
      E-mail: boyan.nalchadjiiski@chaos.com
