.vrscene missing textures
  • .vrscene missing textures
    I have some problem with missing textures inside .vrscene files exported from 3dsmax from VrayForModo under Windows.
    everything works under windows but when I switch to my OSX textures missing from .vrscene files.
    Please help.
    www.studio-grid.net | creative imagery of unbuilt architecture
    Gumroad Facebook Vimeo Linkedin
    Hey, bbgrid.
    Well, I guess you need to use two options added to V-Ray Menu Tab. You can try first with "V-Ray Asset - Relink" and next one with "V-Ray Consolidation".
    If the problem continues existing please send the scene file with textures to check it.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      after this problem still exist.
      I avoid it by changing image paths inside .vrscene file manually with text editor
      On WIN file paths goes like D:/folder/folder/image.jpg and on OSX like /Volumes/disk_partition_name/folder/folder/image.jpg
      also to avoid this for now you can go to V-Ray/import .vrscene and you will be prompted for missing maps and you can relink it from there,
      which not happens if you add .vrscene item under item list and only add path to .vrscene file.
