Hey everyone,
I'm testing out distributed render and i'm getting some problems with networking. My Router that is connected to the internet is not in my room so I have to use wifi. It's a 5g Wifi so it's not too bad. When I rendered a large test scene , it took around 20-40 seconds before I was able to see the the render node buckets to start rendering.
Is 20-40 seconds bad? I have no baseline for that but I'm assuming it will be better if I use an ethernet cable. my wifi says the speed is 866.7 Mbps but it is 3 out of 5 bars in Wifi Signal.
I then tried a crossover cable but it was not able to connect. I got this to work with Modo's render network before but it was very troublesome. I could transfer files between computers but Vray was not detecting the render. I think it was sending the render to the original wifi ip address(connection timeout in event log). I then tried doing custom Ip address and that did not work as well. Although I think I forgot to put anything in the DNS settings.
I'm thinking about getting a router or using a gigabit switch( bought it but never figured out how to use it). Would the router with wifi disabled be better in this situation?
Sorry, network setups have always been a nightmare for me.
Edit: I don't want to use distributed render with WIFI as a long term solution. I did a 1 hour render test and I lost connection 45 minutes in and the slave did not reconnect.
Edit 2:
Did a test render of a dense scene and it rendered the scene in 12 minutes with the wifi render node. Without the render node it was around 17 minutes. It took 2 minutes for the render node buckets to start assisting. 30% increase in render speed. I was estimating it to be around 60 percent faster.
DR attached to see the delay. I feel like it should hit at least 50% performance increase with a better network solution.
Edit 2:
