Hang setting alsurface sss density to 0
  • Hang setting alsurface sss density to 0
    Tested in 3.5 and nightly 28092
    1. Load the attached file into the Render Vray layout
    2. Press the Start RT CPU button in the top modo toolbar
    3. Set alsurface sss density scale to 0
    4. Press the Stop RT CPU button in the top modo toolbar (dont press stop in VFB)
    RESULT: Modo hangs
    NOTE: Even if you dont press the rt stop button, it leaves modo in an unstable state and hangs trying to close modo down.
    Win10 Pro 64 / AMD Ryzen 9 5950X / 128GB / RTX 3090 + 1080 Ti / MODO
    I am the resurrection, and the life: he that believeth in me, though he were dead, yet shall he live - Jesus Christ
    Hey, funk.
    Thank you for the feedback. I am able to reproduce the issue and I'm going to log into our system.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Just following up on this thread. Any news?
      I tested in nightly 28908 and it still hangs modo
        Tried the same settings in Next for Maya, it doesn't crash
        viewport IPR and frame buffer IPR, it doesn't crash Vray
        Muhammed Hamed
        V-Ray GPU product specialist
        chaos.com
          I think the bug is still there in Next, you just need a Dome light to trigger it and also set the density scale to zero.
          Then you can reproduce it in Maya too.
          Zero for the density is unexpected and should be clamped internally.
          I will write back here when there is a fix in the nightly builds.
          Greetings,
          Vladimir Nedev
            Thanks for checking vladimir.nedev
            The reason this came up is because I was using modo's slider to change the value, and its easy to accidentally slide to 0. I thought it may have been a relatively quick fix to clamp the lowest value internally.
              Yes, I understand how it can happen and it is an easy fix.
              Greetings,
              Vladimir Nedev
                Thanks Vlado!
                Muhammed Hamed
                chaos.com
                  This should be fixed in the nightly build from 2019.02.16 . Note that I forgot to update the change-log, so it's not mentioned there.
                  Greetings,
                  Vladimir Nedev
                    Thanks vladimir.nedev
                      Thanks Vlado!
                      Muhammed Hamed
                      chaos.com
