A new service pack - V-Ray 3.70 for Nuke is available as a free update for V-Ray for Nuke customers.
You can download it from the Nuke download section at chaosgroup.com
and check out the documentation.
Top highlights:
This new version is officially available for Nuke10.0 / 10.5 / 11.0 and 11.1, for both Windows and Linux operating systems.
Here is the full changelog :
New features:
(*) Support for Nuke 11.1
(*) VRayRenderer: Support progressive/interactive rendering on CPU and GPU
(*) VRayLightLinker: Support for light linking
(*) VRayTexRamp: Support for multipoint ramp texture
(*) VRayMtlHair: Support for hair shader
(*) VRayHairSampler: Support for hair sampler
(*) VRayCamera: Support for dome camera
Modified features:
(*) VRayProxy: Add flip axis option
(*) VRayVRScene: Add support for global material override
(*) VRayVRScene: Add support for override snippet
(*) VRayRenderElement: Add possibility to customize Nuke layer name on VRayRenderElement node creation
(*) VRayProxy: Improve hair support with full viewport preview and per-object/per-id scenegraph
(*) VRayTranslator: Automatically reuse the region of interest of the active viewer if enabled
(*) VRaySunSky : Add filter color control for aerial perspective
(*) VRayRenderer: Add console and file log verbosity control
Bug fixes:
(*) VRayCryptomatte: Fix rare cases of unidentified selected matte object in Cryptomatte plugin despite being available in the manifest string
(*) VRayProxy: Reloading a new proxy file does not update the viewport preview
(*) Animated parameters are not properly exported with single frame export
(*) Incorrect frame exported on animated parameter when mblur is enabled
(*) Unwanted keyframe is created for animated knobs when linked or when modifying knob animation curve
(*) Missing light select render element with modified VRayCamera when rendering through command line
(*) Incorrect diffuse shading of textures with alpha channel used directly as geometry material
(*) Command line rendering of animated sequence with scene using LightSelect crashes after 1st frame
Happy rendering and feel free to let us know your feedback !
Top highlights:
- Support for Nuke 11.1
- Progressive rendering - help you fine-tune the look of your renders faster than ever. As you make adjustments to your scene, your rendering will update automatically, taking full advantage of your hardware ? including GPU-acceleration. (https://youtu.be/XvrbFxWiDYg)
- New hair workflows - for the first time, render complete 3D creatures and characters directly in Nuke. Import hair geometry using V-Ray proxy objects, and assign V-Ray Hair material for optimized shading. For even more control, use the new V-Ray Hair Sampler node with the V-Ray Ramp texture to add randomization and color variation (https://youtu.be/vsF2kiLtb-Y)
- Light link support - render scenes more efficiently and quickly by creating light sets to control the relationship between lights and objects in complex scenes using the new V-Ray Light Linker node.
New features:
Modified features:
Bug fixes:
