Projection card opacity issue Vray for Nuke
  • Projection card opacity issue Vray for Nuke
    Hi All,
    We have the following issue with opacity when I am projecting a texture (exr file with alpha) on the card, using a camera projection then out of the projection is rendered red. It is working fine if I use only the texture to project. Since I add Retime or Premult the issue shows.
    Anyone experience the same issue?
    Scene: Vray_Nuke_Error.zip
    Hello,
    Indeed this is not working correctly and I will log it in our bug tracking system.
    As a workaround you could bake the texture by using a Write node after the Premult and load the rendered texture as an input for the Projection.
    Thank you,
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi Georgi,
      This is exatly what we did as a temporary solution. looking forward for the fixed release.
      Thanks,
