VrayDenoiser node does not work when loaded from network
  • VrayDenoiser node does not work when loaded from network
    Hello, i'm not sure if it's the right forum to ask this question but we are adding the possibility to our artists to denoise image in comp using the amazing vraydenoiser node. But our pipeline is loading nuke gizmos, plugins from a network shared folder. Everything is working well except the vraydenoiser node that is outputting a blank error message when loaded from a shared path. When the path is local everything is working well.
    To resume in the init.py if is local :
    Code:
    import nuke
    nuke.pluginAddPath('C:/local_folder/VrayDenoiser')​
    works and we can use the node, but :
    Code:
    import nuke
    nuke.pluginAddPath('//network_folder/VrayDenoiser')​
    ​When we create the node we have this error message :
    We even tried to map the network path to a mapped drive same issue. We can't install locally on every workstation and render farm the node since the pipeline dynamically load eveyrthing for the artist.
    Thanks for your help. We are using nuke 13.0v4
    Hello, maybe there is a better place to ask for this ?
      I'm troubleshooting it. Will write again with more info.
        After some thorough testing, it does work for both network paths and mapped drives. A few things to note:
        1. Make sure the init.py file is in ASCII encoding.
        2. Make sure the VRayDenoiser version corresponds to the Nuke version (downloads here)
        3. Check permissions.
        Also, are there any errors printed in the console?
          Thanks for the answer, now it's working. I don't know what changed but everything seems fine.
