I just tested using the progressive CUDA rendering to render a sequence to disk. Unfortunately this always produces a first frame at low quality, then renders the first frame again at better quality as the second frame to write to disk, and after that everything is one frame out in the sequence on disk.
Attached is my test scene.
This is in Nuke 11.1v3 using VRay 3.70.01
Once I also had the scanline option produce the first frame twice I think, but I can't reproduce this, so maybe i was just getting confused.
The addition of the progressive CUDA option is more than welcome and it'd be awesome to be bale to use it to render to disk reliably as well.
Cheers,
frank
P.S.: Can files with .nk extension please be allowed as attachments in this forum?
Cheers,
frank
