VRayDenoiser works with images done with progressive sampler?
  • VRayDenoiser works with images done with progressive sampler?
    Does this only work with renders done with the bucket sampler mode? When I render out with progressive sampler, it hardly notice any denoise effect in Nuke when I pipe renders through VRayDenoiser. As changing to rendering with Bucket mode, the VRayDenoiser node denoise as usual.
    I am using VRay for Maya nightly build 27280 on Windows 7.
    Thanks!
    always curious...
    It should work fine. Is the noiseLevel element created properly? Is it possible that you opened an older scene where the variance-based sampling was disabled?
      Thanks Vlado. Let me double check on those and get back to you.
      -Jason
      always curious...
        Where do you place the denoiser node? At the end of the pipe? or as far down the pipe as you can before other elements get added over top?
        Brendan Coyle | www.brendancoyle.com
          It's best if you add it before adding other things on top of it.
          Georgi Zhekov
          Phoenix Product Manager
          Chaos
