Unstable Render Nodes Vray Swarm in Revit
  • Unstable Render Nodes Vray Swarm in Revit
    This is the Error while I am trying to render with vray swarm
    [Error] Failed to get configuration from HP-Z820 (192.168.0.164). Stopping V-Ray server...
    [Error] Failed to add DR node HP-Z820 (192.168.0.164)
    What can make this problem?
    Usually, when you have less licenses than the number of nodes. Is this the case? How many render node licenses do you have?
    Ana Lyubenova
    Product Manager
    www.chaos.com
      We have 1 license for Vray and 3 License for Render Nodes .
        Please, use the private messages to send me your username, so that I can check your licenses.
        Also, enter each of both unstable nodes from the Swarm web manager and send us the V-Ray log.
        How to do this -> in the address bar of your browser, you need to type in the following "IP of the unstable node":24267/log (example: http://10.0.2.180:24267/log)
        If you are not rendering, the log will be empty. Therefore, first start a Swarm rendering.
        Looking forward to the requested info,
        Ana
        Ana Lyubenova
        Product Manager
        www.chaos.com
