Setting do not save on synchronise
  • Setting do not save on synchronise
    The project .vprops file is not saving when synchronising the project. This is including when 'Save Local File before and after synchronizing with central' is enabled.
    Is this expected behavior?
    It is not part of a standard worksharing workflow to need to manually save the local file, and as such we are regularly loosing changed settings when V-Ray crashes Revit (still happens often).
    Hardware: Intel i9 9900k - 32 GB RAM - NVIDIA Quadro RTX 4000 & i7 10875H - 32GB RAM - NVIDIA GeForce RTX 3070
    Hi Anthony,
    This is expected in version 3.x. You need to locally save the Revit project to save the V-Ray settings.
    Once we launch the beta of V-Ray Next for Revit (which will be very soon), you'll be able to sync to central even your V-Ray settings.
    I hope this helps.
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
