chaos cosmos white screen
  • chaos cosmos white screen
    Hey there
    I have the following problem I hope you can help me with it
    I can't wait to try this new library but whenever I try to open chaos cosmos it opens as an empty white screen
    Click image for larger version  Name:	Screenshot 2021-02-24 004622.jpg Views:	0 Size:	8.4 KB ID:	1103765
    Go to your download page and download the updated cosmos. It seems the specific donload is a newer version than the ones incorporated.
      in the downloads page you get to download the software itself only
      and the cosmo asset comes as part of it
      and I did download the last version "Vray 5003 for Revit"
        Similar issue for me as well, but within rhino 7. Click image for larger version
Name:	Screenshot 2021-02-23 173130.png
          redownloaded the vray for rhino file and everything was fine. maybe redownload your vray for revit and see what happens, hopefully that works. cheers
            You're right arch_mado. I cannot locate the download of the "standalone" cosmos now. Guess there is a reason they removed it. My bet is they have updated the main install files instead.
              Same problem here... downloaded and installed the latest file several times. Running the latest version of Vray and license server.
Name:	BLANK COSMOS.JPG
                Hi all,
                You need to manually find and uninstall the Cosmos browser from Windows Add or remove programs panel. (Mind that during the beta, that service was called Chaos Cosmos Browser)
                Once you uninstall it manually, reinstall V-Ray for Revit. This time, it will install correctly.
                Let me know the results.
                Best,
                Ana
                Ana Lyubenova
                Product Manager
                www.chaos.com
                  I installed the last Vray version on two different PCs and still have the same problem
                  looks like a common issue
                    I was advised the following and it worked!
                    1) Uninstall the existing Chaos Cosmos Browser program. On Windows, go to Add or Remove Programs, find Chaos Content Browser and click on Uninstall.
                    2) Remove any files from previous installations by deleting these directories (if they exist):
                    C:\Program Files\Chaos Group\Content
                    C:\Program Files\Common Files\ChaosGroup\Content
                    C:\Users\<YourUserName>\Documents\Chaos Cosmos
                      Thanks, Ana & David
                      this solution worked for me
                        Great to hear!
                        Let us know what you guys think about Cosmos.
                        Ana Lyubenova
                        Product Manager
                        www.chaos.com
                          Loving it so far!!
                          Only one issue, can't get the default material library back. It was erased when uninstalling and can't figure how to get it back!
Name:	Material asset library.JPG
                            Got response by Chaos Support. "Start Revit by choosing right-mouse-button Run As Administrator" easy fix!
                            Up and running!! Here is a fast first try:
Name:	150918 Living Room V09_low.png
                            • #15
                              very helpful. It worked for me
