deactivate displacement when use in blend materia
  • deactivate displacement when use in blend materia
    hi
    hope you are fine
    i dont know if it is an essue or not
    when i use a material who have a displacement map in blend material it lose it
    in my case i am tying to get a wet asphalt material, basic material have his displacement material, when i pute it in blent i lose displacement material and whenn i add the disp-map in blend material i lose reflection (look pic) Click image for larger version
ID:	1113838Click image for larger version
    Hi moneech ,
    The material-embedded displacement is already a legacy. I'd suggest you to use the separate displacement asset. It can be created from within the Geometries menu of the Asset Editor and can be assigned separately. It will affect the entire geometry no matter what type of material is being used. Have you tried this out?
    There are a couple of threads on that matter you can have a look at here and here.
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      hi Ana Lyubenova
      yes i tried and as i said in post when i do it i lose the reflection "water effect"
        Can you send us the model along with the wet concrete textures? Use my email ana.lyubenova@chaosgroup.com
        Ana Lyubenova
        Product Manager
        www.chaos.com
