Error When Starting a Render
  • Error When Starting a Render
    Hello,
    I'm getting error after starting interactive and production render. Any help is greatly appreciated!
    Graphic card:
    GPU processor: NVIDIA GeForce RTX 2070 SUPER
    Driver version: 466.63
    Driver Type: DCH
    Direct3D feature level: 12_1
    CUDA Cores: 2560
    Core clock: 1815 MHz
    Memory data rate: 14.00 Gbps
    Memory interface: 256-bit
    Memory bandwidth: 448.06 GB/s
    Total available graphics memory: 16348 MB
    Dedicated video memory: 8192 MB GDDR6
    System video memory: 0 MB
    Shared system memory: 8156 MB
    Video BIOS version: 90.04.95.00.86
    IRQ: Not used
    Bus: PCI Express x16 Gen3
    Device Id: 10DE 1E84 40081458
    Part Number: G186 0012
    Hello Erik,
    This error is quite common in Revit and unfortunately, it does not provide us with any additional info.
    Are you able to reproduce the issue and send us the most recent V-Ray for Revit log file from C:\Users\<your username>\AppData\Roaming\Chaos Group\V-Ray for Revit 20xx
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      Hello Erik,
      I've got the same things. it look like to be because of Proxy. If you have RPC without proxy assignate to it, you can resolve to assigne one.
        This error indicates that something went wrong when exporting data to V-Ray. It could be a proxy, yes, it could be a material, or fur, displacement and any other feature that comes to mind. That's why, in order to identify what exactly is causing it (and to also fix it for everyone else) we need the log file.
        Ana Lyubenova
        Product Manager
        www.chaos.com
          PM sent Ana.
          In my case it looks like proxy/cosmos objects issue. I made it work by reloading cosmos models and re-creating new RCP/revit objects assignments to vray cosmos.
