Vray Swarm Issue for Windows Server?
  • Vray Swarm Issue for Windows Server?
    Hello,
    I'm trying to test out the V-Ray Swarm features. I have a V-Ray for Revit license with (2) render node licenses. Locally I'm able to render just fine, but then when I try to add the node it isn't working.
    I'm able to get it to show up in the V-Ray Swarm pool and the status is 'assigned', but in the Render Progress Dialogue, still getting:
    "[Error] Failed to add DR node SCHOOL (192.168.86.29)"
    I'm trying to run this off my Windows Server, which happens to have a good GPU I'd like to utilize for rendering.
    My first question would be, can the swarm computer be a Windows Server 2019 Essentials Operating System? Any help would be appreciated. Thanks
    Dear kyle_bigart, hello.
    I will move now the discussion to V-Ray for Revit forum, since Chaos Cosmos isn't involved in this issue === DONE ✔️
    Thereafter we will continue the investigation with the specific teams involved.
    Thank you for contacting us.
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Hello Kyle,
      We have some questions with regards to the error you get.
      1. Which version of V-Ray for Revit are you currently using?
      2. Can you reproduce the error once again and send us the most recently generated V-Ray for Revit .log file from C:\Users\<your username>\AppData\Roaming\Chaos Group\V-Ray for Revit 20xx\Logs (you can use my email to send the log ana.lyubenova@chaosgroup.com)
      3. Prior to running Swarm, what value have you set the Render Engine and Image Sampler settings to? (These are in the Renderer tab of the V-Ray Settings panel.)
      Looking forward to your response.
      Best,
      Ana
      Ana Lyubenova
      Product Manager
      www.chaos.com
