Some strange highlights on render.
  • Some strange highlights on render.
    Hi! There is some strange highlights in rendering, geometry doesn't have any gaps. Thanks in advance.
    Hi! Can you send us the model?
    Ana Lyubenova
    Product Manager
    www.chaos.com
      (link removed)
      Last edited by Ana Lyubenova; 27-07-2022, 01:25 AM. Reason: link to project cut by admin
        Hello again veent_veent ,
        Can you please also add the corresponding V-Ray assets (textures, proxies) that you used as we can't reproduce the issue without them. The easiest way to pack them is by exporting a .vrscene file as archive.
        Please, whenever we request any files, don't attach the link to them directly on the forum. Email them either through our support system or directly at me ana.lyubenova@chaos.com
        Best,
        Ana
        P.S. How to export a .vrscene file as archive?
        1. Navigate to Settings/Paths & Sharing tab and enable the Export As Archive option under the V-Ray Scene Export Options
        2. Make sure the problematic view is selected as Current View in V-Ray
        3. Expand the Render toolbar panel and select Export V-Ray Scene. This will generate an archive file which can then be sent.
        Ana Lyubenova
        Product Manager
        www.chaos.com
          Also, can you let us know if you're using the most recent V-Ray for Revit version? And if not, can you update to it? (It can be downloaded from this link.)
          Ana Lyubenova
          Product Manager
          www.chaos.com
            52023 version
              Hi veent_veent ,
              It seems like the issue is caused by the Primary GI engine being set to Irradiance map. That was the default value in the past and most probably it was transferred when you migrated your project. Set the engine to Brute Force as shown on the screenshot.
              Teodora Kosheva
              QA Specialist
              V-Ray for Revit
              www.chaosgroup.com
                Oh, dear Anna and Teodora, sorry for my carelessness... when I copy file to my google drive and open it at another computer I forgot to reconfigure Vray settings. I don't know why but in this case settings get lost. But at least problem with ceiling now solved.
