Could it possible to make chamfer edges by material.
  • Could it possible to make chamfer edges by material.
    Tried make it via edges to bump slot, but it doesn't work for me.
    Dear veent_veent​, hello.
    Please be sure that you have added Bump Attribute and the Mode is set to Local Space Bump.
    Previously it was named Bump Texture Channel​. We will improve the docs now.
    Here is a quick example, please try the following:
    TS​
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Another way is to follow the green note here by using the Bump material workflow.
      Example:
        Thanks for answering. I have some issues with may stair, in both cases you wrote above I've got this strange streaks...
          Could you please share another screenshot from the Asset Editor to see where is this Edges Tex actually loaded?
            Here it is
              Could you please check and share with us what Texture is loaded in Bump (above the additionally added Bump attribute)?
                this is it
                  Hi again,
                  You don't need this Texture there.
                  Please take a look again at the shown examples (1 and 2) from me above.
                  Edges Texture is loaded only in the Bump attribute (added separately) with Mode changed to Local Space Bump.
                    Thanks a lot.
                      You are welcome!
                      Contact us again if needed.
                      Wishing you a wonderful week.
