Render a Surface
  • Render a Surface
    Hello, i tried to render a curved wall but the result of the render shows only half of the surface. Is the form too complex to render it?
    Dave
    Hi Dave,
    Can you make sure that you have set the resolution to Crop Region? It seems like you are using the default 800x600 resolution now.
    Regards,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      i did it and it does this..
        i found out why it did not work. i deleted the massing after i created the wall on the massing. the Problem is when i do not delete the massing the Surface of the created wall doesnt appear. But if i delete the massing it doesnt show the shape
          Send us the Revit file pls.
          Ana Lyubenova
          Product Manager
          www.chaos.com
            Can´t upload it here. Invalid file. How can i send you the file? Thanks for helping me
              I'm contacting you in private message. Check your messages at the top right corner of the forum page.
              Ana Lyubenova
              Product Manager
              www.chaos.com
                Hi Dave,
                The problem appears to be Revit related, as it is reproducible also with the Revit render engine.
                I recommend you to contact Autodesk.
                Best,
                Ana
                Ana Lyubenova
                Product Manager
                www.chaos.com
                  ok, i will contact them! Thank you!
