vray can't render with GPU
  • vray can't render with GPU
    hi
    when i render with CPU it goes perfect
    but when i render with GPU i get this error : V-Ray: FastSSS2 "scatter gi" param is always "on" in RT GPU
    coud you help me plz and thank you
      Hi Moneech,
      Can you please reproduce the error and do the following:
      After the crash occcurs, navigate to: C:\Users\<your username>\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 20**\Journals (where 20** is your Revit version; and AppData usually is a hidden directory, so you will need to unhide it).
      This folder contains Revit journal files. Order them by date and send us the most recent one at support@chaosgroup.com (please, point my name under subject)
      Note that the Revit journal file does not contain information about your project etc., it only contains data related to the correct/incorrect program functioning as well as errors which might have occurred.
      Best,
      Ana
      Ana Lyubenova
      Product Manager
      www.chaos.com
