Project VRay settings file
  • Project VRay settings file
    Hello Everyone,
    Where does VRay for Revit save the VRay settings for a Revit project file?
    If rename my Revit project file, all the VRay settings get lost, and I have to start from scratch. The problem also exists, if I want to continue my work on a different computer.
    Can the setting be found somewhere, and possibly it be loaded into a project?
    Thanks a lot,
    Best Regards,
    Gabor
    Gabor Nagy
    narmer architecture studio
    www.narmer.hu
    The V-Ray for Revit settings are shared externally from the Revit project in order to avoid conflicts when using a central file.
    If you rename your Revit project by using the Save As command, all current V-Ray settings will be saved along with the new file.
    Yes, V-Ray settings can be shared across computers. In the following video, you can find description starting at 26:00min https://www.youtube.com/watch?v=ImeRErsAGz0&t=1974s
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      And link to our doc page: https://docs.chaosgroup.com/display/...-ShareSettings
      Ana Lyubenova
      Product Manager
      www.chaos.com
        Thank you very much, that worked great!
        Gabor Nagy
        www.narmer.hu
          Happy to hear it!
          Ana Lyubenova
          Product Manager
          www.chaos.com
            Ana, I tried to follow this link but it didn't get anywhere. Would you mind updating this? Also, does it work with v-ray 5 or did the procedure change?
            https://forums.chaos.com/forum/v-ray...-settings-file
            Thanks for your assistance!
            //a few minutes later
            This appears to be what I'm looking for now, hopefully the will work. Figure I asked and answered in one post!
            Setting up a Workshared Environment - V-Ray 5 for Revit - Chaos Help
              Hey Rick,
              In addition to what you've already found, mind that the V-Ray settings have been saved within the Revit project file (since version "Next" of V-Ray).
              In case of multiple users doing worksharing, each user's settings can be found in the Project Storage drop-down in the Paths & Sharing tab of the V-Ray Settings dialog. All V-Ray assets in the Asset Editor are common for all users, whereas the replacements of materials & geometries as well as lighting and environment settings are user specific (and can be transferred across users). The workflow with .xml files sharing is still valid too.
              Let me know if you have any specific questions.
              Best,
              Ana
              Ana Lyubenova
              Product Manager
              www.chaos.com
