How get Sharper Shadow in exterior view with HDRI light
I'm new in Vray for Revit and will like to have the reflecting sky in my Curtain wall glazing form the HDRI and I'll like to have a sharper shadow the I get for the sunlight illumination, any help pleases,
For the glazing material, use V-Ray glass material. Make sure the Reflection is set to white and Fresnel is on.
For sharper shadows with dome light, you need to use an image with a higher dynamic range.
If you can send us a screenshot, I think it will be easier to advise you.
This, and also have suitably small light sources in the HDRI used.
A big light source will produce soft shadows, while a smaller one will produce sharper ones.
