Does Vray for Revit have a maximum limit to the render image output size?
Revit closes abruptly when the scene is being prepared by Vray and about 50% into the 'preparing light cache' phase of the render, then Revit closes. This is when I set the resolution to a larger size. If I render same scene but at a lower size it works fine, but the resolution is too low for the size printout that I need to provide to someone.
Thanks for any help you can provide.
Dave
PS: I wish there was a standard setting recommendation checklist for this. It is painful experimenting so much when the client is needing something quickly. Not sure why Chaos makes everyone experiment on their own. This should be pretty simple and would result in much more users in the end.
Dave
