Autodesk Shared Materials paths
  • Autodesk Shared Materials paths
    When I render a Revit sample in V-Ray, I get the error shown in the attached picture. Notice that the path to the Autodesk Shared Materials Texture is missing.
    A texture exists at C: \Program Files (x 86) \Common Files \Autodesk Shared \Materials.
    Where does V-RayRevit get the path of the Autodesk Shared Materials Texture? And where can I redefine it?
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hi Yuji,
    This issue is fixed in our next major version. Until we release it, the workaround is to add the path under the Paths section found in the Paths & Sharing tab of the V-Ray Settings dialog.
    Here is the path you need to add: C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats
    Let me know if you need further assistance.
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
      Thank you for your advice!
      I'll try it.
      oakcorp.net
      v-ray.jp
        This issue is important, so I received a request from my customer to fix it in the current version.
        oakcorp.net
        v-ray.jp
          Due to some major updates we've done, we can't fix it in the current version. Besides, there is a working workaround which I posted above.
          Let me know if you can't make it work and I can assist you via a remote call.
          Best,
          Ana
          Ana Lyubenova
          Product Manager
          www.chaos.com
