Toon Base Material
  • Toon Base Material
    Hello. I am trying to select a different base material in a Toon material. All I appear to be able to do is either select none or select the current base material.
    If I 'edit' the current base material I can't see how to get back to the Toon material, so all changes are lost as I can only save the base material.
    Any help much appreciated.
    V-Ray for Revit 3.60.04
    Changing the base material is not supported in the current V-Ray for Revit version. However, it will be available very soon.
    Also, please update to V-Ray for Revit 3.70.05, as the version you are using is outdated.
    Best,
    Ana
    Ana Lyubenova
    Product Manager
    www.chaos.com
